Neuvěřitelné, tamijácký TEU regl s BEC!
Compact forward/reverse ESC for electric R/C cars. Reverse function can be disabled. Features heat and over current protection functions with LED indicator. Compatible with LF batteries and includes a battery cutoff function to prevent over discharging. Equipped with aluminum heat-sink.
BEC system included. Compatible with receivers from Tamiya and other manufacturers. Max. continuous current (FET spec): 60A. Input voltage: 6.6-7.2V. Compatible motor: Sport-Tuned Motor, motors over 25 turns. Receiver output: 6V/1A (BEC). Dimensions: 39.4x36.5x15mm (not including protrusions). Weight: 44.5g.
Cena kolem 50 USD.
