V12
Opat som rypol do tej nepodarenej V3S - rozhodol som sa, ze na nu dorobim plne animovane riadenie. Zatial sa venujem iba trialovej :
Podarilo sa mi to poriesit tak, aby fungovalo aj skrucanie ramu :tleskam: Ked to niekoho zaujima, tu je XML podvozka :
Kód: Vybrat vše
   <PhysicsModel Mesh="trucks/pragatt_chassis">
      <Constraint
         ModelFrameChild="spojovacka_cdt"
         ModelFrameParent="wh2_cdt"
         Type="UnlimitedHinge"
         AxisLocal="(0;1;0)"
         PivotOffset="(0;0;-1.78)">
      </Constraint>
      <Constraint
         ModelFrameChild="t1_cdt"
         ModelFrameParent="FrontBone_cdt"
         Type="Prismatic"
         AxisLocal="(0;1;0)"
         MinLimit="-0.1"
         MaxLimit="0.2">
         <Motor Type="Spring" Spring="100000" Damping="3000"/>
      </Constraint>
      <Constraint
         ModelFrameChild="t2_cdt"
         Type="Prismatic"
         AxisLocal="(0;1;0)"
         MinLimit="-0.1"
         MaxLimit="0.2">
      </Constraint>
      <Body
         Mass="4000"
         ImpactType="Truck"
         <Body Mass="50" ModelFrame="rLMF" Collisions="None" AngularDamping="3.0" >
            <Constraint AxisLocal="(0;0;1)" MinLimit="-65" MaxLimit="0" Type="Hinge" >
            </Constraint>
         </Body>
         <Body Mass="50" ModelFrame="rRMF" Collisions="None"  AngularDamping="3.0">
            </Constraint>
         </Body>
         <Body
            ModelFrame="FrontBone_cdt"
            Mass="2000"
            ImpactType="Truck"
            <Constraint
               Type="Hinge"
               AxisLocal="(1;0;0)"
               MinLimit="-7"
               MaxLimit="7"
               <Motor
                  Type="Spring"
                  Spring="120000"
                  Damping="80000"
            </Constraint>
            <Body
               ModelFrame="front_axle_cdt"
               Mass="500"
               ImpactType="Truck"
               <Constraint Type="Fixed" MalleableStrength="0.001" />
               <Body Mass="50" ModelFrame="wh1_cdt" Collisions="None"  >
                  <Constraint AxisLocal="(0;-1;0)" MinLimit="-40" MaxLimit="40" Name="ChassisSteer1" Type="Hinge" >
                        <Motor Damping="1.0" Force="150" Tau="1" Type="Position" />
                  </Constraint>
                  <Body Mass="50" ModelFrame="spojovacka_cdt" Collisions="None"  >
                     <Constraint AxisLocal="(0;1;0)" Type="UnlimitedHinge" >
                     </Constraint>
                  </Body>
               </Body>
               <Body Mass="50" ModelFrame="wh2_cdt" Collisions="None"  >
                  <Constraint AxisLocal="(0;-1;0)" MinLimit="-40" MaxLimit="40" Name="ChassisSteer2" Type="Hinge" >
                        <Motor Damping="1.0" Force="15000" Tau="1" Type="Position" />
                  </Constraint>
               </Body>
               <Body Mass="250" ModelFrame="t1_cdt" Collisions="None"  >
                  <Constraint AxisLocal="(1;0;0)" MinLimit="-40" MaxLimit="40" Type="Hinge" >
                  </Constraint>
               </Body>
               <Body Mass="250" ModelFrame="t2_cdt" Collisions="None"  >
                  <Constraint AxisLocal="(-10;0;0)" MinLimit="-40" MaxLimit="40" Type="Hinge" >
                  </Constraint>
               </Body>
            </Body>
            <Body
               ModelFrame="CabinBone_cdt"
               Mass="2000"
               ImpactType="Truck"
               <Constraint
                  Type="Hinge"
                  AxisLocal="(1;0;0)"
                  MinLimit="-14"
                  MaxLimit="14"
                  <Motor
                     Type="Spring"
                     Spring="120000"
                     Damping="60000"
               </Constraint>
               <Body Mass="50" ModelFrame="steering_w" Collisions="None"  >
                  <Constraint AxisLocal="(0;-1;0)" MinLimit="-360" MaxLimit="360" Name="ChassisSteer" Type="Hinge" >
                        <Motor Damping="1.0" Force="150" Tau="0.04" Type="Position" />
                  </Constraint>
               </Body>
            </Body>
         </Body>
      </Body>
   </PhysicsModel>
wh1_cdt a wh2_cdt - naboje kolies s brzdovymi valcami
front_axle_cdt - bona prednej napravy, je parent pre wh1_cdt a wh2_cdt - pouzil som constraint typu fixed, ale iba formalne, s minimalnou pridrznou silou (MalleableStrength="0.001")
t1_cdt a t2_cdt pomocou vonkajsej vazby typu Prismatic a Motor simuluju pruzenie, ako Parent je pouzit predna cast ramu, takze cely ram sa pekne kruti - ako v realite.
spojovacka_cdt - bona pre pohyblivu spojovacku riadenia
Pekny :)
Hele co jsem nasel - krasavice! To byl nejakej prototyp?? :O
sim_ma
Myslím že prototyp to byl ale vypadá to moc dobře
V12
Bol to prototyp T815, skusali na nom nove chladenie motora a asi aj prevodovky. Apropo - ked sme u prevodoviek - V3S mala hlavnu prevodovku 4 alebo 5 kvaltovu ? Nejako si nepamatam...
Peter23
V3S má 4 stupňovú hlavnú prevodovku.
Tie prototypy T813 6x6 - bolo ich viac, existoval aj 3-stranný sklápač.
V12
Diky, uz som to konzultoval s jednym soferom.
Inak V3S na http://steamcommunity.com/sharedfiles/f ... =636610208 bola zaktualizovana :
- prepracovana predna naprava s plne animovanym riadenim zbrusu novym sposobom, aby zostalo zachovane skrucanie ramu
- trialova verzia dostala hydroservo, takze riadenie ide rychlejsie, valec posilovaca je pekne viditelny vpredu na naprave
- standardna verzia dostala schopnost tahat standardne privesy (zapriahnut za nu vlecku plnu kratkych klad ale nie je moc dobry napad)
- zmenene prevodovky, uz su iba 4 stupnove
- viacero drobnych zmien na kolesach
lukino343
v12 po mojej phoenix daš do hry aj avie? mam valnik , skrinovu,odtahovku ,frugon
V12
Chlapci, Bregel chysta nieco absolutne bombasticke, mal som cest na tom zapracovat :
Truggy bude mat 100%-ne animovany podvozok domakany do sialenych detailov, vratane kolovych redukcii. Takto urobene auto v ST nie je. Jeho Toyka je super, ale na toto jednoducho nema ! Cely den som sa babral s ramenami priecnych stabilizatorov, ani za svet sa mi to nedarilo spojazdnit. Nakoniec som ale zaznamenal uspech a uz to funguje. Uz sa tesim, ked to Bregel dokonci.
Tak tomu říkám pořádný model dotažený do konce. :OK:
V12
Jj, Bregel umi. Uz ta Toyota bola super, skoda tej prednej napravy, pri plnom rajde je z blizka vidiet vsetky nedostatky. Tento Nissan zatial ziadne nema.
Supeeer! :tleskam:
lukino343
včera som sfotil :) celu pozlatenu 148
V12
Prave pracujem na Juggernautovi upgradujem podvozok. A opat narazam na limity Havoku - pri takto tazkych vozidlach je fyzikalne prepajanie jednotlivych casti velmi gumove, vsetko treba riesit viacnasobnymi constraints. Nakoniec sa mi to ale podarilo, nie som sice na 100% spokojny, ale podvozok je dostatocne tuhy. Takze klasika - animovane rajdove capy, spojovacky riadenia na vsetkych napravach su uz hotove, pripravujem si hydraulicke valce riadenia. Uz teraz ten podvozok vyzera o triedu lepsie, ako bol povodny, kde boli iba napravy. Cela ta mechanika je krasne viditelna, takze bude na co pozerat, aj ked auto ako take nie je bohvie co - vyzera akoby bolo povarene z toho, co konstrukter nasiel na dielni (alebo gulagu ?) na dalekej Sibiri :twisted:
kesi
Tak jsem si to taky stáhnul, i když můj multimediální notebook to dá jen v kombinaci střední a nízké detaily ve FHD. Stejně koukám, že mezi vysokými a nízkými detaily není nijak propastný rozdíl. Pohybuji se většinou mezi 20-40FPS, dobré je, že i na těch 20FPS se to dá hrát.
S čím se ale hodně peru je kamera, to je vážně hrůza. :-( Dá se to nějak poladit?
Vaterra Ford F-100 Ascender 4WD
Coach
kesi píše:Tak jsem si to taky stáhnul, i když můj multimediální notebook to dá jen v kombinaci střední a nízké detaily ve FHD. Stejně koukám, že mezi vysokými a nízkými detaily není nijak propastný rozdíl. Pohybuji se většinou mezi 20-40FPS, dobré je, že i na těch 20FPS se to dá hrát.
Vyskúšaj spintires plus mód.
