SpinTires má další aktualizaci.
SPINTIRES®
CELÉ TEXTY TITULKY
14. pro.
Chernobyl DLC Hotfix 1
Spintires® - zane5
Fix for the main menu "continue" button.
Fix for the CHERNOBYL EXPLORER achievement.
Sdílení:
13. pro.
v1.4.0 (full) now available!
Spintires® - zane5
Added / New
-Option to remove the 60FPS cap.
-Orbital camera mode.
-Right-side view angles in classic camera mode. Cycle by tapping or holding 1 or 2.
-Possibility to zoom in freecam mode.
-Proving ground selector.
-Main menu background animation.
-Ingame ads. They can be disabled in the settings menu.
-Korean and Chinese languages added.
Improvements / Adjustments
-Mousewheel now works to scroll on the controls menu.
-Removed slight FOV increase when trucks were driving at >6m/s.
-Heavily reduced the jump between each zoom level.
-Replaced free camera precision mode by 2 keys (Numpad 3/9) to change movement speed.
-Mechanisms that were previously actuated using number keys in the advanced menu now use ctrl+number. This is because camera modes are starting to creep up on number keys.
-Freecam controls now have their own section in the controls menu.
-Slightly smoother fog on the F1 minimap if your graphic card supports VFetch.
-Areas explored by remote players in MP appear clearer on the minimap than simply uncloaked ones.
-Depth of field settings no longer vary with daytime states.
-Reduced rain volume
Fixes
-Fixed missing force feedback for some joysticks and gaming wheels.
-Removed the Manual gearbox achievement from gameplay and from the achievement menu.
-Classic camera will no longer move above obstacles when driving under obstacles. Unless there is no room under.
-Multiple intro pictures being displayed, with a separation in the middle of the screen. The intro will now display a single picture.
-Removed error in log about missing UserMediaPaths.xml. This file is optional.
-Dev menu now hidden when taking screenshots if "Show HUD on screenshots" is disabled.
-Achievement requiring a type B-130 have been updated to work with its newer version.
-Fixed a possible mesh corruption when generating extensionless meshes with close to 65k vertices.
Additional note:
Most achievements have been rechecked and earned at least once during tests.
https://store.steampowered.com/news/?appids=263280
https://store.steampowered.com/app/1151 ... nobyl_DLC/
