Axial SCX30
Napsal: 30.09.2025 15:00
1/30 SCX30 Jeep Wrangler JLU 4X4 RTR Brushed Rock Crawler (Battery & Charger Included), Green
https://www.axialadventure.com/product/AXI-2261.html
Axial 1/30 SCX30 Jeep Wrangler 4X4 RTR Features
- Axial SCX30 sub-micro crawling platform
- High-performance chassis with full-time 4-wheel drive
- Angled skid plate and ramped axle housings to slide over obstacles
- High-clearance rear links to avoid dragging and hangups
- Forward weight bias for climbing stability
- Easy-access transmission
- Compatible with SCX24 aftermarket gears for different ratios
- Officially licensed Jeep Wrangler JLU scale ABS hard body
- Molded parts for body customizing - including overland accessories and extra comp fender set
- Clipless body mounting for easy chassis access
- Officially licensed Black Rhino Atlas wheels
- Officially licensed Yokohama Geolandar X-MT tires
- Officially licensed ICON Pro Series front and rear bumpers
- Axial 88T brushed motor
- Low mounted electronics for optimal CG
- Damped shocks
- Full ball bearings
- Spektrum SLT2 2.4GHz radio system
- Spektrum 7.4V 160mAh 2S 30C LiPo battery
- Spektrum 0.5A USB 2S charger
- Ready to run - nothing else required
