Tak už jsme to konečně našel:
Produced in 1936. Its a 6×4 pickup truck based on GAZ-M-1 chassis (modified), it has cabin and gearbox from GAZ-AA, cargo section from GAZ-4, fenders, radiator grill and wheels from GAZ-M-1. Interestingly this truck has little support wheels between first and second axis to help help the car go over bigger obstacles. GAZ-21 was just an experimental model, it was never mass-produced. Only few unites were produced.
Wheels 6×4
Engine
Formula 4 cylinder gasoline
Power 40 hp @ 2800 rpm
Displacement 3,285 liters
Compression ratio 4,2:1
Gearbox 3+1 speeds
Fuel tank 40 liters
Max speed 87 km/h
připadá mi to, že to u nábojů nemá žádný klouby, žeby něco od tatry?
edit, teď koukám znova a asi tam sou...teda vypadá to na prachovky přes klouby...takže beru zpět:)
**Honza** **Original since 1981** **#RTRCZ team driver**
Zprzněnej Samurai..nebo, že by Samurai po indicku :?:
Jeep Wrangler na CCčku,LR Discovery I ve stavbě, Avia A31 Turbo 4x4 odložena na neurčito
http://trewor.rajce.idnes.cz Hlava plná nápadů ale jsem moc línej je realizovat
